Hi All,
I bought a Vaio in Italy and installed an OEM version of Vista in english. Most of the software could be reinstalled with the new language but the Vaio Update 4 did not ... and could not be dowloaded from the Sony web site. Any idea?
Thanks in advance
as I have understood beside you is not installed Vaio Update 4 скачай with with site Vaio- link and ustanovi. or use reconstruction Vaio all program, centre reconstruction Vaio section : will restore file
After changing from the original Sony OEM operating system with a clean install, Vaio Update will not work. You will have to update your Vaio manually.
Sony only provides automatic updates for the known original system.
