vaio vgc-v2m fires up but no HD light. blank screen. just a power light
werdas
Visitor
when I switch on it fires up but no HD light. blank screen. just a power light,no POST nothing....
any one got any ideas.
so if any one can help !!!!!????
ideas?
i would be gratefull
as i do not know should I sell it for spares or try to repair it
4 REPLIES 4
werdas
Visitor
any ideas is it motherboard dead or video?
Thalamus.
Champion
Hi werdas,
welcome to Club VAIO.. :slight_smile:
Trying to pinpoint the cause without seeing your Vaio could be difficult, do you hear anything running from inside your Vaio. :thinking:
As to what to do, if you're unsure on what's the cause you could see if a local repairer in your area can give you a free quote then you can decide on your next course of action.. :wink:
werdas
Visitor
hi,everything seems to be running, fans etc. can hear when HDD accessed, tried to remove CMOS battery for a couple of minutes,tried to remove the ram module, just in case to see the difference, but it still won't post, tried to recoconnect the video card...nothing
could it be the mobo or vid or ram ?
werdas
Visitor
also tried other HDD, no changes
