I have upgraded from Vista to Windows 7. I have installed all the Drivers recomended by Driver Toolkit software. I have installed and run Vaio Update.
Only one problem, the disk tray open close button does not work.
I can open the tray from Windows Explorer, but only if there is a disk in the tray, if not I must use a pin to open the tray manually.
I guess that there is some other driver required, but Device Manager show no problems.
Anyone got any suggestions??
Hi DonkeyDog,
If your VAIO has a removable battery, could you try removing the battery and re-inserting it? Sometimes a simple power reset is all you need.
Cheers,
The_Black_Rose
It does seem strange that the other buttons work OK. A physical problem is unlikely if it works in Windows.
Do you get a "Ejecting" message on screen when you press the eject key?
Do you get a screen message when you press the 'Mute' key or change the volume?
What happens when you press S1 or S2? Does a box pop up allowing you to program what S1 and S2 do?
If you do not get these pop ups then you are missing the 'Setting Utility Series' utility. Let me know and I will upload a copy for you.
Hi DonkeyDog,
Let us know if there's a difference.
Cheers,
The_Black_Rose
Tried removing the battery and then re booting. No change.
As regards on screen messages. S1,S2 and Tray open do not produce any on screen message (I am not sure what the S1 and S2 buttons are supposed to do. Film Mode? How would I know if they are functioning).
Mute, Volume up and down, all give appropriate on screen acknowledgments.
If S1 and S2 are working, press and hold and the Setting Utility Series will open. You can then choose yourself what you want to use these buttons for:
Multiple Monitors, External Monitor, Max Screen Brightness, Hibernate, Sleep, open an application of your choice .... and more.
I seems you do not have this Utility installed - I have sent you a link by email.
Worth a try to get the keys working - not sure if it fix the eject problen!
If you want to try with the original VGN-AR' Drivers / Utilities:
Sony Shared Library 4.1
https://mega.nz/#!e4VSQKbD!rHw81dlF-TzAE4ggbP_1kzHp_4Lm92qAsHX9w0zezaQ
Sony Firmware Extension Parser
https://mega.nz/#!yxNS2I5b!Bbn5ax4d9_FMWVsljnz_B8odngu0ZljcsUfKDhjtMEk
https://mega.nz/#!rpFkEYAS!NE2H4eZ0aESNxhivhrjUQ4I62Nbv7lboGmI5DOs8qfE
VAIO Original Function Settin
https://mega.nz/#!25c0ySBZ!_lm9lcQJfbZdNXK5fvLrETMTrQ9YyuAmQnHCEEif_1k
VAIO Event Service 3.3
https://mega.nz/#!64VUwK6D!3TYjg9f1gfKonCc44swh65iB1krL6hlAfi5Z83dctQk
Manolo
