vgn-ar31s nvidia geforce go 7600 gt driver problem.
profile.country.en_GB.title
dieoxin1983
Visitor
I get a blue screen when i use the latest driver for the video card.(version 7.15.10.9813)
I can only get it working with standerd vga drivers by disabling the video card.
is there another driver that i can use or is there another way of sorting the problem out?
2 REPLIES 2
Blencogo
Are you still using Vista?
The latest driver is 7.15.10.9813a dated 11/06/2007 - is this the one you are trying to install?
What is the message on the blue screen?
:thinking:
dieoxin1983
Visitor
still using vista and yeah after a couple minutes or hours i get the blue screen as pictured.
when windows looks for a solution to the problem it says that the nvidia card is not working properly
