Hi can anyone help me switch on bluetooth on my notebook i have just purchased today and it tells me to use the wireless key but shows no bluetooth,
Hi yorkiefishing,
welcome to Club VAIO..
Switch the wireless LAN to the on position, the switch can be found on the front left of your Vaio.
Then click next to or above the Bluetooth in the Vaio Smart network window.
Note make sure the wireless light next to the switch is on..
Hi thanks for your reply but i have done that and its on the right hand side no buttons on left side front, i have internet but in the window it shows no bluetooth
Hi yorkiefishing and welcome.
I think you need to check carefully the full specifications sheet that came in the box with your Vaio.
I do not think Bluetooth is installed in the AR61E or the AR61M and is only available with the AR61S and AR61ZU.
VGN-AR61E Specifications
