i require all the drivers for my laptop as i had a HD failure, i kept meaning to create backup discs but kept putting it off
has anyone got a copy or a place where i can download them as i only seem to get patches and updates from the VAIO site.
Thanks
Hi knox102 and welcome.
Did you purchase the VGN FZ210CE in the EU, as this would appear to be a USA/Canadian model?
If so you will need to check the US site for original drivers.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGN-FZ210CE
I had the laptop imported into the UK when the Dollar was 2 for 1 so worked out cheaper, well until the import tax
i have looked on the US and CAnada website but all i seem to get is updates and no full driver downloads.
Thanks
There seem to be a number or originally installed drives and utilities in the link I posted but possibly not the ones you require.
Unfortunately it would seem that recovery disks are no longer available for your model from Sony USA
Click HERE for details
