I recently bought a Vaio VGN-X505VP and I noticed tha the audio is veri low. With default setting You can hardly hear it... Also raising up the volume control to the max it is still very soft...
Is it right??? Or my Vaio is defective??
Ambrogio
If you have all the volumes as high as they can go then yes.
Uhm I had the opportunity to try another one of the same model and it has the same problem... I think that the integrated mini-speaker is not so powerfull...
Apparently this is nothing new
