Hi there everybody.
I have VAIO FE31M with WMC2005 and I've just signed for upgrade to Windows Vista Home Premium via Moduslink.
As this new OS still in my opinion requires some fixing and improvements, I have two question about "still-to-arrive-to-my-mailbox" Vista Premium and it's installation on my laptop:
1. It says during registration for this update that Sony will provide Vista DVD with all Sony VAIO utilities, software, drivers, services etc. that is required for proper useage and running of my lappie. Is that true ??? Or will I have to find and install those things by myself (you know, built-in camera, bluetooth, touch-pad, power management, setup center and all those things you want to be there). I'm especially concerned about volume level display (OSD bars) cos I know people have trouble to get it to work on Vista...
You know what I'm talikng about, don't you ???
2. Because I use software that may not be yet compatibile with Vista (like Adobe products), I just want to try this one out to check how it's running and if everything is all right, but then I would like to go back to WMC2005 for some time, at least untill everything settles down and proper updates and new versions of programs are released.
Does installation of Vista make any changes to original recovery partition of laptop or could I still use it to overwrite Vista and go back to recovered "C" partition with WMC2005. (I have two partitions: "C" 40GB and "D" 120GB).
Or even better...I have made image of "C" partition with WMC using Acronis True Image 10. Could I use this image to bring back my old OS from Vista ??
Any help will be highly appreciated.
THX
Hi ChesterPL,
The upgrade to Vista DVD will have all the drivers/utilities/applications included. It will be just like the Recovery Discs you made when you first purchased your Vaio.
That is the theory anyway - in practice a few things don't seem to work 100% and new software will need to be released to fix them. The Camera still has an outstanding problem and a few other things remain 'buggy'.
Your Recovery Partition should remain intact - your Recovery DVDs would also work (if you haven't made amy, make sure you do before you install Vista) - you can also restore your Acronis Mirror (although this will take many hours!!)
The only thing you can't restore is the Vista BIOS Update.
If I do this update but then I want to go back to WMC2005 will it still work properly ???
