VPCEC3S0E - No Shutdown!!
profile.country.en_GB.title
levilyn
Visitor
I am having problems shutting down my computer.  I click shutdown it goes through the shutting down process and then re-starts again.  Can anyone suggest anything.  I have just done a full factory restore but it is still doing it.:smileysad:
11 REPLIES 11
levilyn
Visitor
I have now tried to uninstall Vaio Care. But even though it appears to have gone it still loads it when the machine switches itself back on. Very frustrating.
rich912
Contributor
Hi Lynda,
I can't be certain on this but I'm beginning to suspect that you have a faulty/sticking Vaio Assist button.
If this is the case all I can suggest is to shut down, remove the battery and power adaptor and then try tapping the button a few times to see whether this will free it up - then reattach battery and adaptor and see whether it still turns itself on.
Rich
Go n-éirí an bóthar leat
