VPCEH3N6E Touchpad not working
profile.country.en_GB.title
imSonyuser
Visitor
The touch pad of my VIAO has stopped working. The mouse pointer is in the center of the screen and does not react to any touchpad actions. I have restarted the notepad many time but of no use. The external mouse thru the USB works fine.
Can you help me resolve the issue?
Tags (2)
1 REPLY 1
rich912
Contributor
Hi imSonyuser,
Check that within Vaio Control Center > Keyboard and Mouse > Pointing Device that the touchpad is enabled. With some models the Touchpad can be enabled/disabled by holding down the Fn key and pressing F1.
Also check in Device Manager under Mice and other pointing devices that you have a Touchpad listed and that it is reported as working correctly (Properties).
Given the above information we may have a better idea of whether this is a software or hardware problem.
Rich
Go n-éirí an bóthar leat
