Webcam software for SOny Vaio Vgn FW21L???
SOLVED
profile.country.en_GB.title
ricallbu
Visitor
i updated my laptop to windows 7, my webcam works however i have no webcam software and i cant find it anywhere on the sony site, i want to take pics with my webcam but i cant
anyone know where i can get the software for the built in webcam for this laptop
thanks in advance :slight_smile:
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
The original Arcsoft Webcam Companion was only licensed by Arcsoft to be used as part of the Sony Operating System. It is not downloadable from Sony.
If you had upgraded to Windows 7 from the Sony OS, you would still have this software but if you do a clean install of a Retail version of Win7 you lose the license rights and you will have to buy replacement software.
:anguished:
1 REPLY 1
Blencogo
:anguished:
