Hi - does a windows 7 driver actually exist for the above? Naively I have upgraded my Vaio VGN-S5XP/B o Win7 but as far as I can see there is no driver update available. Has anyone had the same problem - and solved it?
Hi lisfes,
You may possibly be able to solve this problem by installing the relevant Nvidia driver with a modified .inf file.
Follow this link and make sure you read the ‘Quickstart Guide’ on the right toward the bottom of the page.
http://www.laptopvideo2go.com/drivers
Rich
