Windows 7 clean install VGN-FS295VP Driver Problems
JoeH1
Visitor
I hope someone can point me in the right direction to get my Vaio working propoerly.
I recently did a full (clean) upgrade from XP to Win7 on my trusty VGN-FS295VP. All went really well and after tracking down a few elusive drivers the machine runs well and is stable. Only problems relate to the keyboard and power management.
Since upgrade none of the fn keys wrok. No volume up/down, brightness, contrast, s1,s2, etc. Also power drains from the battery really quickly; I can only run for about 30-40mins before crtical battery level is reached.
Can anyone tell me which drivers I need and where to get them to get things reaonably back to normal?
Thanks
4 REPLIES 4
Blencogo
Hi JoeH1 and welcome.
Try installing all the Vista utilities for your model here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-FS295VP&os=7
To get the keys working install the following IN ORDER: -
Sony Utils DLL
Sony Shared Library
Vaio Event Service
Setting Utility Series
You may also wish to install most of the others as well like Vaio Control Centre.
:wink:
JoeH1
Visitor
Hi Blencogo,
Thanks so much for your very quick reply.
I had to try your suggestion twice but then all worked just great.
First time I did not uninstall the various drivers & Utils. Second time, I uninstalled all four items that you mentioned and restarted the computer. Then I installed each driver in the order you mentioned and made sure I restarted after each install.
The machine runs brilliantly and all keys work. Hopefully this will also reduce my battery usage as I can now dim the screen when running on batteries.
Is there a way to setup a power scheme so that the display automatically dims when on battery power?
Thanks again for such a great response.
Joe
Blencogo
Hi Joe - glad that all worked!
You can do what you want in the Power Management Option in Windows 7.
Have a look at this link: -
http://blog.enterpriseitplanet.com/green/blog/2009/01/how-to-manage-windows-7-power-settings.html
You can set up High Performance, Balanced and Power Saver Modes as you like them.
:wink:
JoeH1
Visitor
Thanks again.
I've had a look at this but I cannot see how to automatically reduce the brightness of the screen when on battery power. I'll keep digging through the options though.
Cheers
