Hello - I'm using an iMac with Mojave 10.14 installed. I'm getting the WirelessImporterDaemon is not optimised for your system which implies it is a 32bit application and will cease to work when the next version of the operating system is launched next month.
Does anyone know if this is going to be upgraded to 64bit please?
Many thanks
James
Hi Bowood1,
I believe this is related to the Wireless auto import section of PlayMemories Home. When I checked the recommended computer environment for it, it seems that Mac OS 10.14 isn't supported. I'd recommend having a look here: http://support.d-imaging.sony.co.jp/www/disoft/int/pcenv/en/contents/index.html
Cheers,
The_Black_Rose
Thanks The_Black_Rose
Had a look at the spec. Seems strange the current operating system isn't supported with this app when others are. Perhaps Sony are quietly dropping it. When I upgrade to the latest op system next month it'll stop working for sure, which is a shame.
Thanks for taking the time to investigate this for me.
James
