I have a VAIO LA-2 series
I am trying to play Call of Duty Modern Warefare 2 but I get the message “Couldn't creat a 1024x2048 render target surface: Wrong texture format.”
Any suggestions would be apriciated. Thank you.
You need to install the latest graphics driver for your NVIDIA® GeForce® Go 7400 GPU.
Sony has not provided a bang up-to-date driver so you are probably using the original 3 year old driver.
You will need to go to www.LaptopVideo2Go.com and download one of the latest WHQL Visa drivers (I assume you are still running Vista?). This will not install as it is and you will have to download a modified .INF file for your GPU.
Click on the tutorial in the right-hand column on the above site for instructions: - Frequent Questions -> Quickstart Guide
You do this at your own risk of course. Also I would guess your LA2 is going to struggle with this game at any more than the most basic settings anyway.
