XP Service Pack 3 ?
picassojb
Visitor
XP Service Pack 3 ?
Hi everyone. I'm being nagged every day upon startup to install the following update: Microsoft Service Pack 3. My Vaio notebook is a VGN-FJ1Z/W running Windows XP Service Pack 2.
Is it totally safe to do this update? I worry as my system has been running perfectly for years and I have lots of precious programs and data.
Has anyone experienced problems after updating with SP3 ?
Many thanks
John in Rome
[email protected]
5 REPLIES 5
Thalamus.
Champion
Hi John,
welcome to Club VAIO.. :slight_smile:
I installed SP3 on my FS without problems but other members have had problems..
See the following post: Windows XP Service Pack 3
picassojb
Visitor
Many thanks for the quick reply, Thalamus. I suspected updating to sp3 could be dangerous! Would you know how to turn off the update nag screen? I would have expected to see the usual 'don't ask me again' toggle but there is none. I would like to have the option of remaining current with other updates however.
thanks muchly for your help John
Thalamus.
Champion
Hi John,
from memory I think you can...
Click on the update prompt, then choose custom install..
Uncheck SP3and then a window appears asking if you want to never be told about this update, tick the box..
Hopefully that will stop the SP3 update nag screen..
picassojb
Visitor
Dear Thalamus,
thanks !!
John
Thalamus.
Champion
You're welcome John
