- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Can't transfer music to NWZ-E464
I've had the NW-A805 for years and it's been so reliable and easy to use. I always used the sonic stage program that came with it to transfer music onto it and had no problems whatsoever.
I bought the NWZ-E464 last week and the sonic stage program isn't recognising it. The only way to transfer music is by drag and drop as far as I know. And when I go into my computer-libraries-music none of the music that I transferred into the sonic stage library from cds etc is there! I can only see some of the music I've downloaded from the net, which I was able to transfer using drag and drop. Is there a way of either getting my new mp3 recognised by sonic stage as that would solve all my problems easily? Or of transferring all my music in sonic stage to computer-libraries-music? Any help would be greatly appreciated!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi SonicStage is no longer supported by Sony products, you will need to convert your files to MP3 and use them via Windows Media player, or Drag & Drop via Explorer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Oh I hadn't known that, I'll do that so. Thanks a million for your help.
