- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
February 2013
February 2013
CDX-DAB500U front panel not ejecting cleanly
I've just finished installing a CDX-DAB500U into my minibus. It's working perfectly at the moment apart from the fact that when you try to eject the front panel, the upper part of the clamp on the left hand side is not releasing. The only way to get round this is using a thin piece of metal to lift the clamp upwards so that it releases.
Is there any easy fix for this or do I have to take it back to Halfords and get it exchanged?
0 REPLIES 0
