- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
hi I have a peugeot 307 year 2003 to which i have instaled a cdx-gt250mp.
it dosent keep it setings when you turn the car off.
is there a wiring problem all i done was plug it in
thank you
Message was edited by: ticktaylor
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi ticktaylor,
welcome to questions & Answers..:smileyhappy:
Not 100 sure on this but it sounds like your radio is not getting any power to retain the stored settings when you remove the ignition key, so unless anyone has a better solution I would suggest having an radio installer check out your CDX-GT250MP's wiring..:smileywink:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi ticktaylor,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thank thats what i thought it probly is as it keeps the settings until i turn of the ignition off.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes that would be a good place to start but it's probably best to get a local radio installer to check it out though..:smileywink:
