CDX-GT300S Not storing settings
profile.country.en_GB.title
rossmac15
Visitor
Hi, my stereo unit doesn't save any presets for radio tuning or for audio controls. If is switch the car off and remove the key, then restart the car all setting i adjusted return to factory settings.
How do I solve this?
If it helps, my car is Astra 1.6 SXI 2004...
1 REPLY 1
lalahill
Visitor
Hi,
Swap the red and yellow wires over, Had the same problem and this was the solution
