Google Cast support for SRS-X7
Kapten_G
New
It was great to see that the newly announced SRS-X88 and SRS-X99 will support Google Cast for audio. I am hoping that also the SRS-X7 will get this support in a SW update. Will that be the case?
Best wishes
1 REPLY 1
Anonymous
Not applicable
Hi there
You will need to contact Sony directly to get an answer from them:
https://shop.sony.eu/shop/mimes/openAccess/legal/contact-us/contact_en_GB.html
However, you will probably get the answer of "Sony does not comment on future firmware developments or releases" or something to that effect :slight_smile:
Cheers
