Headphones iOS app - Speak to chat setting not persisting
niallfrench
New
This bug occurs with v9.5.1 for iOS 16.5 but has existed for a significant time.
It occurs for WH-1000XM4 and WH-1000XM5 devices.
When the Speak-to-chat feature is disabled, the app periodically (I suspect on iOS app and/or firmware updates?) resets the setting to re-enable Speak-to-chat.
This is extremely annoying.
1 REPLY 1
Piscie
Hello @niallfrench
Try resetting the Headphones Connect app settings
Also make sure both headphones are running the latest software version. Version 2.5.0 for the XM4 & 1.1.3 for the XM5
If it doesn't work, try resetting both headphones settings: https://helpguide.sony.net/mdr/wh1000xm5/v1/en/contents/TP1000541013.html & https://helpguide.sony.net/mdr/wh1000xm4/v1/en/contents/TP0002752746.html
Also check if this happens only on iOS or also on other devices.
