Hi,
I have a sony voice recorder and I've managed to lose the usb cable, does anyone know where I can get a new one?
Solved! Go to Solution.
A lot of time has passed and no answer. I guess you must have found a suitable cable by now? :smileygrin:
In case anyone else needs an answer to this question: this voice recorder needs a standard USB 2 cable with a USB A connector (for the computer) to a USB mini B connector (for the voice recorder). These cables are commonly used to connect many different devices, such as voice recorders, cameras and mobile phones, to a computer, and are readily available on-line and in the high-street and some supermarkets for a few UK pounds. :smileyinfo:
BTW, I see that the cable supplied with my ICD is a basic black one, about 1 metre long, made in China and not a special one by Sony.
Hope that helps!
Hope that helps!
