MDR-1RBT Prestige headphones Quastion
SOLVED
profile.country.en_GB.title
rostjapa
Visitor
Hello,
I'm thinking to buy headphones for my ps Vita, I want to know is this model will work with ps Vita, according to reviews in i-net they can be wired, that mean they can give sound, but will microphone works?
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.FR.title
ClarkLong
Yeah you can use this headset with the PS Vita to listening to sound.
The microphone/remote cable is designed to be used with iDevices... The pins of the mini jack are specifics to Apple devices so that cable (and the mic) can ramdomly work or not with other devices.
The official psvita earbuds with mic/remote works with iPhone so I guess the pin are the same.
2 REPLIES 2
ClarkLong
rostjapa
Visitor
thanks , got them long time ago, lol awesome headphones, thanks to Sony
