- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Media Go and album art resizing.
Dear Sir/Maddam,
It appears that "Media Go" automaticaly resizes my album art that is attached to mp3 files; I am using the album art function with different softwear to attach lecture slides to the corresponding audio files; the resize is rendering them unreadable.
Is there any way to turn off this resize function, if it is indeed Media Go that is doing it.
Thank you kindly.
Iain
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Dear Sir/Maddam,
I have been able to assertain through observation, the following: Media Go is changing the recorded or rather, stated image dimansions, without actualy changing the image file size. This happens when I use Media Go to change any of the files text tags.
Once this has been done, if I save the file after editing tags in my other softwear "mp"Tag" the image is then resized to the dimensions stated by Media Go.
This is a real shame as I otherwise like your softwear. My only current work arround for this problem is to use alternative softwear to modify file tags for my library; I am sure that you can understand the inconvienance that this imposes.
Thank you kuindly for your attention.
Iain
