MP3 PLAYER HELP PLZZ
hello ive recently found my sony NW-A805 mp3 player that i lost ages ago
the only problem i have is that i no longer have the sonicstage software on my laptop to transfer files ;-( ive searched high and low for the cd but cant find it anywere, and for some reason sony no longer support this software so i cant even download it on here
can anyone please help?
1 REPLY 1
Nobody-in-particular
Contributor
Hi soundwave77, Sony have stopped supporting Sonic Stage because it was not compatible with the later versions of Windows.
When you connect your walkman to your pc does it appear as a removal drive? If it does then have you tried to drag and drop your files into the respective folder on your walkman?
