Music Player Apps
jolb72
Music Player Apps
Hi there
I would like to ask if anyone can recommend an alternative music player app to the one that comes with the Sony NW-A306 music player that I have. I find this app along with Sony's Music Center for PC just plain boring and very limiting on what you can do with it.
Before this, I always used Apple ipods along with iTunes which you could do so much more with and had better features like being able to crossfade tracks, which is something I would like to do again with a different app that is compatible with the Sony NW-A306. I would also need it to be able to play 24bit high res files, flac, m4a, mp3.
Could anyone suggest such an app that is more like Apple's old ipods and a music center for the PC that is similar to iTunes.
Thanks
Jo
1 ODPOWIEDŹ 1
MaggieGreene
Hi @jolb72, you can install any app you want on the NW-A306 by following the steps here: https://helpguide.sony.net/dmp/1301/v1/en/contents/TP1000733516.html You can use Amazon Music or any other app you prefer.
