I'm trying to register my new walkman.
What series is a nwz-b172 and how do i find the serial no?
Thanks
Jan
Solved! Go to Solution.
Hi once you are on the My Sony page you should be able to enter the details as follows.
The serial should be located on the rear of your walkman.
