profile.country.en_IE.title
sussy123
Visitor
nwz-s765 cable
I recently damaged my USB charger cable for my MP3\Walkman so I bought a replacement from Amazon.  The problem is when connected to any PC or Laptop the player is not detected however to charge the player I can plug the cable into a USB plug (i.e Blackberry charger) and the player charges from the main socket no problem with the new cable.  Any ideas why laptops\PCs dont see the player yet it can be charged using the new cable???
2 REPLIES 2
profile.country.en_GB.title
daempii
Visitor
Be sure that you will insert the USB cable to your fastest USB port. That usually is the problem.
juaperez6
New
Hi Did you get your answer?
