- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
SONY DRIVE-SHX
I have just bought a secondhand car it has a Sony Drive-shx. It is a DAB radio and CD player with a removable facia. I have no instructions on how to use it, in particular how to change the time on the digital clock. Any clever person out there got any ideas. Many thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
Can you give the actual model number. I will then get you the instructions.
Message was edited by: tennysonman
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Tennysonman,
My son has bought a 2nd hand car (a 2003 VW Golf V5) with a Drive SHX radio CDX-DAB6650, which is not working due to previous chaotic rewiring of the Drive SHX and a VW re-badged Sony 6 Disc cd changer with a label marked
*CW23Z8C4692434* SONY
1DINCDC 3B7 035 220
FR SDN HW: 0011 SW: 3705 D8/03
I would very much appreciate circuit diagrams for these two particularly the CD Changer where the plug fitted is now NOT plugged into the radio (as the radio is not the orginal one fitted) and has been "rewired" so that the blue female plug is not connected and the smaller female plug four wired with single wire plugs and sockets being blue/.white, red, yellow and green/blue (?).
Kind regards
David
