profile.country.de_DE.title
barboun
Visitor
SRF- M900
Hello every one . After a long period (about 2 years) i decided to listen music from my SRF-M900 . I changed bateries and when I turned it on it was a big suprice for me . The FM band had replaced from 88-108 Mhz  to  76-90 Mhz. How i can fix it ?
3 REPLIES 3
wherzig
Visitor
Hello,
I do have the same problem.
If I press BAND there are also new  channels named 1CH until 12CH.
FM band ist restricted to exactly 76-90 Mhz.
Please help.
i fixed the problem in an unusual way: i put in the batteries with reversed polarity for 8 seconds. when i replaced the batteries with the correct polarity everythig was absolutely fixed! Don't ask me how and why: it just happened!!!
good luck!
profile.country.RO.title
cosmingpx8
Member
Hello see that the defect might be jumping the digital gunner
