When I first got the headphones,they were bundled with this rechargable battery.I used them for about a month,till they started randomly switching off,doing nothing and switching back on.I tried some normal AAA batteries,and they worked just fine,so I figured it was a battery problem.I used about 4 normal batteries till I bought a couple of rechargeable ones again,and they worked just fine,until they had to be charged.Suddenly,the same exact problem occurs,and it randomly switches off for no reason,after merely 2 mins of use.As I am writing this,the headphones are turned on,and as such are basically silent,except for some 30-60 second excerpts every 5 minutes.It seems that the longer they are used without being shut off,the longer the delay between them turning on and the smaller amount of time they actually do what they are supposed to do.
