When i use a USB stick in my car stereo, although the music is tagged and shows, the folders just have a number, i.e. folder 1, I have named the folders but they dont show on the stereo?
Thanks for your help.
Jim
Solved! Go to Solution.
Tagged wrong I'm afraid, what is happening is your mp3's are probably ripped from different sources so the tagging isn't the same throughout a single album, only way to sort it is to strip and re-tag using something like Mp3tag or similar, mixed rip rates will also cause this so if you have 2 files in 160kbps and 8 in 192kbps the HU will split them as two different albums.
