Volume resets on NWZ-E474 after i turn it off? plus fw question.
profile.country.en_GB.title
jahumph30
Visitor
Hi, I have just bought the NWZ-E474, it all seems a nice player and don't have any other issues with it, when i use it i always have the volume at about 26-30, i am finding that each time i turn it off then back on, the volume is always reset to 15 and is a bit annoying already and ive only had it a day lol
is this a fault as it seems a silly feature as i would expect a lot of people would prefer the same level each time they turn it on, you can then just turn it down yourself if you wish rather than always having to turn it up each time.
I am not sure if there are any software updates, my fw currently shows as v2.0, so not sure if there is a newer one i can get anywhere that fixes this issue?
Can anyone help?
thanks
james
Tags (3)
1 REPLY 1
jahumph30
Visitor
Hello?
