- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
What is the best file format for the nwz z1060
Currently all my music files are in atrac codec, and think Im looking to get the best sound out of my new nwz z1060, so insted of converting to mp3, I would rather import form cd, and edit files, folder, artwork, and tags as I import
On the Nwz Z1060 what is the best file format to convert your cds from to play on this model
Music will be either played with sony own software, or with a possible music app like winamp
Message was edited by: StartTheCar
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi it all depends on how you like the sound, if you dont mind then stay with MP3 or WMA, i prefer Flac but they take up a lot more space, try making a version of each with only one track and listen to the difference, happy testing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have been out and about today, and took my nwz z1060, loaded it last night with some mp3 files, and alos streamed from spotify
The mp3 tracks, they sound very crisp, and hearing more stuff than before on other sony mp3 models
The other half of my tracks loaded by spotify, and with gapless play, it sound good
Now as you say, I need to compare sounds, so guess it will be spotify v mp3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Would also agree that FLAC is the way forward but it seems manufacturers are not increasing their storage capacity to keep up with the growing demands of FLAC users. Winamp can rip to FLAC and add all the necessary metadata for your music.
You question also depends a lot on what ear/headphones you are going to use. I have a NWZ-F805 and use Westone W4R earphones. These earphones are incredibly good at resolving detail so using FLAC gets the best out of them. I tried some budget earphones and as expected I could not tell the difference between 256k MP3 and FLAC. It all sounded rubbish! :
