- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
XDR-DS16iPN iphone 6 compatible?
Hi is that product iphone 6 and 6 plus compatible and if yes, does it matter if the iphone wears a slim cover?
Thanx!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Airsmac,
welcome to the Sony User Community Forum..
the XDR-DS16iP has a 30pin dock connector so if you want to use an iPhone 6 or 6 plus you would need to purchase an iPhone lightening adaptor..
Will it fit would depend on the the supporter, which I don't think is adjustable on this dock, I have successfully used an iPhone 5 & 6 with a lightening adapter in a similar Sony dock without issue so I would expect you should be able to do the same with your dock..
Hope this helps.?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My mistake I was reading the specs for the XDRDS16iP & not the iPN..☺️
Therefore as long as the iPhone 6 fits onto the lightening port then I would expect that it would work ok but it might be a bit more difficult getting the iPhone 6 plus to fit due to the larger size..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In addition to the above, if the iPhone 6 or plus do not fit onto the docks port you could try using a 8-Pin Lightning Male to Female extension adapter which may give you a bit more room..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
XDR-DS16iP has the older 15 pin connection..
If you have an iPhone 6 why not visit a local retailer (a quick google lists Tesco, PCWorld & Currys) & try with your iPhone before you buy..😉
