Kto dodał ten temat do Ja też
richardlister6884
Bravia KDL-55W755C not responding
Hi,
I have a problem with my KDL-55W755c
If it is left for a period, say 6 hours the LED will shine but the TV is not on. I can turn the TV on with the remote but then it doesn't respond to the remote, the LED doesn't change and I have to turn the power off to the TV after theis it works fine. I can't power it down with the remote or the power button at the back of the TV, it has to be completely switched off at the socket.
I have tried a reset and hard reset of all settings and still seems to do it. I did install a couple of apps before this all started happening. It doesn't always do this. I have uninstalled the apps and also purged the cache.
Any suggestions?
