- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
October 2020
October 2020
My TV is rebooting but only while using the smart TV components : running Android 8.0.
I'll be watching Netflix or YouTube and the TV will reboot, sometimes in a continuous loop depending on the app being used.
If I watch TV, then there are no problems and everything functions fine with zero problems. Switch to apps and it becomes a lottery.
I have reset the TV a few times and that hasn't made any difference.
Solved! Go to Solution.
