- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi all
Have a really random and strange issue on my 55xh9005 and it's really hard to explain but I'll try. Unfortunately I can't take a pic of the issue either as it's really random and is literally a quick flash.
So far I've noticed that the problem only seems to appear on terrestrial channels, don't really notice it when streaming netflix / prime / chromecast.
When watching TV, I get a random white flash appear on the screen. It literally lasts like a second or less and there is no pattern that I can see which makes it appear more or less. The only way I can describe it, is that it is a flash of white outline of everything on screen.
Not sure if anyone else has experienced this. I have done a full factory reset on the TV but the problem still exists.
Any suggestions would be great
Thanks
Solved! Go to Solution.
