Wie heeft Ik ook gebruikt bij dit onderwerp
Frenkv
Nieuw
Spotify connect doesn't work STR-DN1080
Hi,
I'm using the str-dn1080 for a couple of years now and since the last firmware update M41.R.0518 the Spotify connect function doesn't work anymore. (Not visible in Spotify app)
I can only use Chromecast built in but it is not possible to use the music preset audio.
I see a lot of people posting on the web with the same issue. Sony can you please come with an firmware fix to solve this problem.
