When will the VRR update be rolled out for th A80j model? I've heard it was already rolled out at some TV models from Sony, but at the A80j it stays silent...
Niestety na ten moment nie znamy dokładnej daty aktualizacji do modelu A80J. Do tej pory pojawiły się aktualizacje do X85J,X86J,X89J ale planowane są również dla innych modeli z 2021 roku.
Unfortunately, I don't have any information about the A80J update release date yet. So far update was released for X85J,X86J,X89J but there are plans to update other 2021 models.
Thank you. Much appreciated.
I hope very soon. 🙂
Best regards,
Adrian
Hey Adrian, the update has been enrolled only for X85J_X86J_X89J series. But it will be available for all models soon as per Sony.
Thanks for the heads up.
Soon, means within few months I hope? 😉
Best regards,
Adrian
Hi Adrian,
I guess this is the case, few months period.
Sounds good.
Thanks.
