Taką odpowiedź otrzymałem od dostawcy sygnału TV
krzysiozak1
Applies to: Sony KDL-32WE610
I received this answer from the TV signal provider. Good day,
in Sony TVs we have encountered a situation where, when the TV is turned off, the power to the module is disconnected, so the recorded program cannot be decoded by our card, which necessarily does not work then.
If this additionally happened after updating the TV's software, it means that it has been changed in the software. Is it possible to change this, e.g. in the settings, you should ask the manufacturer of the equipment.
TOYA Technical Assistance Department
2 ODPOW. 2
Ekspert_Sony
Skontaktuj się z naszym działem wsparcia technicznego w celu uzyskania pomocy, możesz to zrobić przez formularz https://services.sony.pl/supportmvc/pl/Contact/Email?cat=electronics lub telefonicznie pod numerem: +48 223060694.
HannahEd01
Hey krzysiozak1, is it possible to translate the header of your post? I'm not sure what are you after..
