I have checked the user guide and various web sites but I haven't been able to get an answer as to what the MicroSD specifications are for this device (SGP321).
I'd like to know what the maximum capacity of MicroSD card is for this device, and if it supports SDXC cards. I'd like to get a 64Gb SD card. I'm currently using a 32Gb SDHC card.
The Android version on my Tablet Z is 4.1.2. I don't know if this version supports the exFAT formatting type needed for memory cards larger than 32Gb.
Solved! Go to Solution.
