Xperia Z2 Styus query
kickstand
Hi folks, I have a silly question really, as I am new to Sony, only picked up my new Xperia on Friday and still getting to grips with it. None of my previous stylus appear to work at "all" which seems strange as they are fine on my IPAD 2 and Samsung Note 2 and Note 3? I use a lot of productivity Apps requiring a stylus and my finger will not suffice as I really need precision. I checked out a lot of reviews prior to selecting Sony and none of them mentioned stylus compatibility issues. Appreciate if someone could advise what stylus works with this tablet. Cheers
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
kickstand
Thanks for the assistance, I am deeply disappointed but such is life. I must be the minority who use productivity Apps. If they have only just resolved finger sensitivity issues I won't hold my breath. Thanks again /K
17 ODPOW. 17
dandy63
Pasjonat
Hi, just dug out a Capaciyive Stylus that i dont use & tried it on my Z2.......works fine, nice & accurate.....if you do a Search on the Forum some people say a stylus works & some dont.
Do you have Glove Mode enabled on yours :smileysmileywink:
kickstand
Thanks for the quick response, I really appreciate the assistance. I am unable to locate glove mode, is it located somewhere obvious?. I forgot to mention It am using a Z2 tablet not phone, if that makes a difference?. Cheers.
kickstand
dandy63
Pasjonat
Hi Kickstand, answered youre earlier post but this section is for the Z2 Mobile.....there is a section for the Z2Tablet.....either post  new question there or one of the Mods will move your posts once they notice.
More chance of your question being answered, good luck :smileysmileywink:
kickstand
Thanks a bunch, tried to recreate in the tablet section to no avail, here is hoping Mod can assist me.
Thanks again.
Thommo
Genius
Threads merged - Do you have a Z2 or Z2 tablet so I can move this to the correct section
Thommo
Genius
Glove mode is found in Settings then Accessibility
dandy63
Pasjonat
Hi Thommo...he has the Z2 TABLET
Thommo
Genius
Cheers and moved
