My tv KDL-40HX800 turns itself off .
profile.country.nl_NL.title
retepski
Bezoeker
My KDL-40HX800 turns itself off after some time, even when I am present watching it.
What can I do about it, all the ECO settings are turned of !
2 ANTWOORDEN 2
breedBenR
Lid
there is a TV turn on / turn off timer menu, seperate from the ECO settings.
retepski
Bezoeker
It turns itself off and directly on again, not once but frequently, at first I tought it had something to do with the attached HDMI cinema system and a Mede8er player.
But after I had both devices disconnected, the problem was not solved, I know about the timer but thats not the problem either.
I will preform a software upgrade, maybe that will resolve the problem, otherwise I will have to return the tv.
Message was edited by: retepski
