Moin Moin,
im folgenden Video präsentiere ich euch das DEV-50. Ein digitales
Fernglas von Sony und eine interessante Alternative zu den klassischen Ferngläsern, da man das gesehene gleichzeitig Foto- oder Videographieren kann, und das sogar in 3D.
Aber seht selbst.
Gruß
Axel
Moin Moin,
hier gibt's noch eine Pressemitteilung zum DEV-50
sowie einige technische Details:
Model name
DEV-50V
Video recording format
2D HD: MPEG-4 AVC/H.264 AVCHD format Ver.2.0 compatible
3D HD: MPEG-4 MVC/H.264 AVCHD format Ver.2.0 compatible
Video Resolution
2D HD: 1920x1080/60p, 50p (PS), 1920x1080/60i, 50i (FX,FH), 1440x1080/60i, 50i (HQ, LP)
3D HD: 2x 1920x1080/60i, 50i
Still image max. effective resolution
20.4 megapixels
Lens
Dual Sony G Lens
Image sensor
Dual 1/3.91" Exmor R™ CMOS sensor
Image stabilisation
Optical SteadyShot™ image stabilisation with Active mode
[wide (3D) / wide to tele (2D)]
viewfinder type
XGA OLED Tru-Finder
Viewfinder
Diopter adjustment: Yes (-3.5 - +3.5)
Apparent field of view: 36.9°(16:9)
Interpupillary distance: 55– 75mm
Magnification range
0.8-12x (2D:Digital zoom is OFF) / 0.8-25x (2D:Digital zoom is ON) / 0.5-6x (3D)
GPS
Yes (without map display)
Interfaces
HDMI output, Multi/Micro USB Terminal
Loudspeaker
Mono
Compatible recording media
Memory Stick PRO Duo ™ (Mark 2) / Memory Stick XC-HG Duo™ / Memory Stick PRO-HG Duo™,
SD/SDHC/SDXC (Class 4 or Higher)
(no internal memory)
Weather resistance
Moisture resistance equivalent to JIS/IEC level 5 protection (IPX5) according to in-house tests
Dust resistance equivalent to JIS/IEC level 4 protection (IPX4) according to in-house tests
Recording and Playback
Times ( 32 GB Memory Card) (2ch)
2D HD PS: Approx. 2h30m
2D HD FX: Approx. 3h00m
2D HD FH: Approx. 4h05m
2D HD HQ: Approx. 7h20m
2D HD LP: Approx. 12h50m
3D HD
3D: Approx. 2h30m
Weight (approx.)
765g (main unit only)
Dimensions (approx.)
148.5 x 72.5 x 157.5 mm
Supplied accessories
Large eye cup, lens cap, power cord, carrying case, HDMI (micro) cable, micro USB cable, finder cap, neck strap, operating manual, NP-FV70 battery, AC adaptor
