XF-1000XM5 head tracking in Cubase 12 Pro
profile.country.CH.title
Subdiakon
New
Wie mache ich in Cubase 12 Pro von den Headtracking-Eigenschaften des XF-1000XM5 Gebrauch?
4 REPLIES 4
SusanneMaier
hi Subdiakon,
meinst du WF-1000XM5 ?
Subdiakon
New
Oh, ja. Da ist mir ein Fehler unterlaufen. Vielen Dank!
Anna_Claus
Hi Subdiakon, der WF-1000XM5 verfügt über keine Head Tracking funktion.
Subdiakon
New
Sony schreibt hingegen:
The *Head Tracking* function is only supported on certain Sony Headphones
models below:
- WF-1000XM5
- WH-1000XM5*
- Linkbuds WF-L900*
- Linkbuds S WF-LS900N*
* These models require firmware update to latest version first. Please
install Sony | Headphone Connect app <> and
connect your headphones to the app in order to update to latest firmware
version.
Head Tracking function allows you to use the *Sony | Headphone Connect *app
to optimize the spatial sound by measuring the angle at which your
headphones are worn. When using Android Head Tracking and spatial sound
compatible services, you can enjoy an accurate audio experience.
*Note: * Availability of the *Head Tracking* function depends on the
smartphone model and Android OS version.
To start the measurement with compatible smartphone and Sony Headphones,
open your *Sony | Headphone Connect *app, go under *Sound* in the main
dashboard, select *Spatial Sound and Head Tracking *and select *MEASURE.*
