charging (oddities)
Nie dotyczy
charging (oddities)
Hello
Purchased device (Xperia X), noted device appeared not accepting of charge correctly, in that sound...akin chimes emitted at android startup decryption input screen...occur repeatedly (until charge cable removed)
Actioned 'hard reset' (apologies meb incorrect terminology) device via : depress power /volume ~hold ;three vibration... / seemed correct charging... so, upon 100% charge, disconnected UCH10... reconnecting as required...charge not accepted.....ensue same pleaseant sounding chime emittance
'hard reset ',.... charge accepted... rinse. repeat
(UCH10 charger clarified functional)
I guess hardware tho' ...perhaps not, have to say unit scheduled for return though obviously if proven unnecessary...
(myfirst Sony)
Thank you fer reading
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Uliwooly
That seems more of a hardware issue than software, contact your Local support to get it inspected
4 ODPOW. 4
Uliwooly
Nie dotyczy
Indeed. I guess mostly curious over button depress combination an if such wer in place so to speak
Uliwooly
You should contact your Local support to get it inspected
Nie dotyczy
Yeh I belive so. Ok, thankyou fer input
Regards
