Default File Save Location
SOLVED
HandyCam
Visitor
Hi,
How can setup my default file save location in my SD card
For example: photos, music, saved files and pictures from my email, whatsapp, etc..
Thanks!
1 ACCEPTED SOLUTION
Accepted Solutions
Lord_viridis
Camera, settings,
Common settings
- Save location
--SD Card
4 REPLIES 4
Lord_viridis
Normally there will be a setting in any app that saves files to choose a default storage option.
webwude
Member
It highly depend on what you are actually using. For example:
- Camera: default internal or SD
- Amazon Video: default internal or SD
- Whatsapp: not possible
- Tapatalk: default folder possible
You see - it really depends on your apps.
HandyCam
Visitor
Hi @ webwude
Thanks for the reply
I looked thru the Camera app and couldn't find an option to set my SD as default save location
Can you please explain the steps?
Lord_viridis
Camera, settings,
Common settings
- Save location
--SD Card
