I want to know my xperia's PIN .
Hi @maeda,
Welcome to the community,
Unfortunately, we would not be able to supply this information, the PIN is setup by the user in this case that would be you, only your would know what this PIN was.
If you are unable to access the device, you may be able to change it using myxperia.sonymobile.com, simply log in and change the PIN using the service.
Let us know how you get on.
